Jeff Davis 800 LTR
teebee
Lake Charles, LA
Does anyone have the correct LCN order for the Jeff Davis 800 LTR system. I have it programed the way the database is showing them and I am not able to trunk the system at all. Of course the database is showing unconfirmed.
milf
Careful, I CAN hear you!
Indianapolis, IN
What type of scanner are ya using? There are tricks with RS ones that make is easier to find the right LCN...
milf
Indianapolis, IN
Not sure if its at all like the RS PRO-97, in that if you monitior a chan of an LTR, that it will display repeater number while manually monitoring the LTR freq..... Check your manual for sure... Also you may wish to post it in the LTR, or the Uniden Forum for your model.
loumaag
Silent Key - Aug 2014
Katy, TX
Umm, it will show the TG ID, which is not necessarily the repeater number; a TG could be being heard on another repeater if the "home" repeater is busy. Of course consistent monitoring usually will clear that up. :wink:
