So is that the only ones they overate on? I keep hearing about these rotary fixed wing tacs and all that other stuff. Just was curious so i could have all these in case of the likely event for this summer. Thanks dude
Air Ops, may contain (depends on the size and who is in-charge)
For Jerrico the freqs are listed below
National Flight Following - 168.6500 110.9
Air Guard - 168.6250 CSQ
Tanker Base Ramp - 123.9750 AM
Sometimes the Forest Simplex is used for Helo/Air Base Ops
West 171.1375 123.0 and 171.7000 123.0
East 171.5000 123.0
Generally two Air-Ground channels, sometimes 3 maybe assigned, depends on how many near-by fires are occurring as well
as the size of the fire they are assigned to
168.3875 A/G 52 - Primary
167.4250 A/G 13 - Secondary
Generally Air-Air channels are assigned as Primary and Secondary and may be sectionalized between Fixed Wing and Rotor
123.7250 AM - Primary
124.9750 AM - secondary
States and/or Regions have been known to also implement their own Flight Following channels, out side of the NFF
151.2650 192.8 is for the DNRC
they also have their own Air-Ground on 151.2200 Pri and 141.4000 Sec
Jericho A/A Primary is 120.1500
Jericho A/A Rotor is 123.8250
Jericho A/G Pri is 169.2000 141.3 used for Recon
Jericho A/G Sec is 169.1500 110.9 used for Buckets/Cargo
Generally a good search will find all, if you spend the time.
