Jersey Milair Freqs.
RadioDitch
Field Operations Member
Not Where You Think
Hey all. What are the best frequencies for central/north Jersey? Specifically the skies around Union County. Thanks all.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
I would start with the milair freqs from the ZNY ARTCC. Don't use the FCC lists - use the ones that follow them
New York (ZNY) Air Route Traffic Control Center (ARTCC) Scanner Frequencies and Radio Frequency Reference
Since these are known frequencies, they can be used to check how well your system is performing in these ranges and whether any improvements are needed.
It might be a bit of a stretch being you're so far inland, but there are a few refueling routes in the area - specifically AR777 which is under ZNY's control
NorthEast AAR Tracks - The RadioReference Wiki
and a bit older map of the route...
AR777 AAR Track - The RadioReference Wiki
73 Mike
