JFK and LGA Airports
eastrocks400
Maybe this should be in the Air monitoring forum but figured id get more here.
There are so many frequencies in the database, which ones should i put in the scanner for air traffic control and any other good frequencies.
JFK LIST
119.1000 Tower
121.9000 Ground Control
123.9000 Tower
127.4000 Aprch/Dpt
128.7250 Terminal Info
135.0500 Clr Dlvr
453.6500 Airport Ops FM 100.0
LGA LIST
118.0000 Aprch
118.7000 Tower
119.9500 Lga Aprch
120.4000 Departure
120.8000 Aprch/Dpt
121.7000 Ground Control
121.8500 Ground Control
121.8750 Clr/Del
122.9500 Unicom
124.4500 Departure
124.9500 Aprch
126.0500 Terminal Control
127.3000 Aprch
128.8000 Aprch
132.7000 Aprch
135.2000 Clr/Dlvr
453.6500 Airport Ops FM 123.0
You might also want to program in the ny nj port authority edacs system in also. Lots of good stuff going on
If you need more freqs let me know
Everything is AM in the list except the 2 op freqs
D
DaveNF2G
Guest
Would you like someone to program your scanner and listen to it for you, too?
eastrocks400
Nope, i have it programmed, but if someone is helping me out they definitely don't have a problem telling me if the frequencies are active.
If you do, don't reply.
The ny nj pa is very active. The other freqs i posted are also active but not all the exciting to listen to.
Nothing like NEW YORK loving going on in here. EASTROCKS400 if you want me to export my pro160 freq i have programmed CSV format let me know and i will post it.
eastrocks400
Thanks a lot xeno but i am saving my trial of PSR till when i really need it.
I will do these few frequencies by hand but thanks again for the offer.
What antenna do you use?
On my pro-160 i use the supplied pull up telescopic antenna and only the 160 for conventional analog stuff
the psr-400 that im waiting for will be for analog trucking system and will use a 800mhz rs rubber duck antenna. Im not to far from lga and about 20min from jfk and i get both system loud and clear. I dont know what part of L.I. your in but you should pick up both airports without a problem. Lately i have been listening to ny nj port auth and its very very active. lots of crazy stuff going on at the airports.
eastrocks400
Im on the southern part of nassau (east rockaway.)
haven't tried listening yet but im sure it will be fine. I'm like 20 min- 30 min away from both
eastrocks400
The database is also showing: 453.65 mhz as a Port Authority frequency for both airports.
What is this?
D
DaveNF2G
Guest
What is this?
Actually, that was my point. If you have the frequencies in your radio already, then you should not need to ask these questions. If you are hearing radio traffic, then the frequencies are active. You should also be able to figure out what a frequency is used for if you listen to it long enough.
This is how it works. If 2 groups are on the same freq they use different tones. JFK ops and LGA ops are on the same freq but use totally different ctcss tones. Go here for more info
PL Tones
Maybe he is asking cause he is new to scanning and might need some help. I did not know anything about trunking till n2nov explained it to me.
eastrocks400
Thanks, i know about that but what i mean was is that PA frequency good??
You only mentioned the Trunked system
Yes all the freq are good. But not active all the time. the trunked ny nj pa system is very active
W2NJS
Washington DC
eastrocks400:
Where in ER are you located? I grew up years ago on Centre Avenue between Clark St. & Ocean Ave.
Tom, W2NJS
Washington DC
eastrocks400
Haha ok. So you went to ER schools... I am in Lynbrook Schools on Durland Road two blocks behind Marion school.
radiomanNJ1
In the land of make believe
Please while trucks may use the system, it is a TRUNKING system.
