Have not heard anything in a while, is it still in use?
pawsrock Member Joined Jun 26, 2005 Messages 235 Location Jacksonville Fl. Jun 5, 2020 #1 Have not heard anything in a while, is it still in use?
Bote know-it-all Feed Provider Joined Dec 19, 2002 Messages 1,046 Location Ft. Lauderdale, FL, U.S.A. Jun 5, 2020 #2 You mean the 460.575MHz analog FM transmitter?
jeff Member Premium Subscriber Joined Nov 29, 2001 Messages 649 Location St. Augustine, FL Jun 6, 2020 #3 That's been off for quite a while. I don't believe they're using that as their back up dispatch anymore.
pawsrock Member Joined Jun 26, 2005 Messages 235 Location Jacksonville Fl. Jun 6, 2020 #4 Bote said: You mean the 460.575MHz analog FM transmitter? Click to expand... Yes that one.
pawsrock Member Joined Jun 26, 2005 Messages 235 Location Jacksonville Fl. Jun 6, 2020 #5 jeff said: That's been off for quite a while. I don't believe they're using that as their back up dispatch anymore. Click to expand... Thanks Jeff, was curious.
S srmanuel Member Joined Mar 10, 2003 Messages 5 Location Jacksonville Jun 28, 2020 #6 maybe I'm totally off base, but I just got a SDS 100 and loaded the Jacksonville City - First Coast Radio settings into the scanner and I'm picking of JFRD just fine here in Mandarin. I believe the radio system is a trunked P25 system.
jeff Member Premium Subscriber Joined Nov 29, 2001 Messages 649 Location St. Augustine, FL Jun 28, 2020 #7 JFRD used to simulcast their dispatch TG on 460.575, it was also used as a back up dispatch with two tone paging. It is no longer in use.
