Greetings,
I am 2 miles away from the Joint Forces Training Base (JFTB) Los Alamitos (CA). They have a 3 frequency VHF NXDN system for Security,
Maintenance, Base Ops, etc. RR identifies it as an IDAS-D system. I use a Whistler TRX-2 here in the shack with a good discone antenna
outside. Using EZ Scan, I can manually program these 3 frequencies into the scanner as 'conventional NXDN', leave the RAN code at 'any'
and the Talkgroup ID at '0' (any ID). I drop these 3 'conventional' channels into a scanlist and scan the list by itself. With this
setup, I can catch most of the traffic and hear it just fine. It is not encrypted. The display even reports the RAN (0) and the
Radio ID of each radio as it transmits. Of course, I miss some traffic because the scanner is not really following the trunked
system.
But,
When I import this trunked system from RR into EZ Scan and let it populate the system with RR's identified talkgroups (ie: DEC 01-0002,
Mode D, Base Security, etc.) and try to scan it as a trunked system (all by itself in one scanlist), the scanner never hears anything
on this system.
I'm wondering if the data in RR is maybe not current? And if not, how could I sleuth the system and grab the current system data so
I can submit updated info to RR?
Looking forward to your suggestions.
73, David, N6HHR
system.
But,
on this system.
73, David, N6HHR
