John Deere business band radio power cord
oppyd20
82788
can anyone tell me if they make an adaptor from the black connector to my kenwood 2 prong . This is in my John Deere tractor, can not figure out what style connector this is. Thanks
clbsquared
Isle of Wight County
I responded to your message. Just cut the connector off and use 2 of the wires. Cover the third exposed wire so it doesn’t short anything out. And also, if you’re running an VHF set up and using AutoTrac with RTK, you may not be able to use a 1/4 wave antenna. It interferes with the signal and will cause you to lose RTK briefly. I switched all of mine to 5/8 gain antennas and also switched all of the Starfire receiver antennas from the rubber ducky to a NMO mounted Antennex.
FARMER522
I have all the part numbers from Deere to make your own connector if you would like them. For years I did as mentioned above just cut that plug off and connect to it, but on the newer Deere's the plug is so short you can't get to it to cut it off so you have to use the plug or carry your power wires down to the power strip.
oppyd20
Thank you but I already cut and spliced it ! Damn farmers have no patience, thank you !
jbt935
Hi, would you share those part numbers? I run int the same issue and would like to make some cables. Thank you.
FARMER522
Yes no problem at all.
57M7501 This is the crimp terminal for the wire.
57M8270 This is the black housing that the crimps slide in.
57M7726 This is a grey lock that slides in the housing that locks the wire in place.
