Well, it seems that I may have to bite the bullet and eventually upgrade to the XT.
As far as mobile reception, I really have had good reception. For example, I'm over in KCMO a lot and from midtown (39th Broadway) I can pick up most of JOCO 25 quite well. I actually get better reception in my SUV than I get on my nightstand. (I'm in the 75th & Nieman area)
The fire and buses come in like gangbusters. Lenexa and Olathe are decent. Shawnee is so so, which is bad as that's what I want to monitor most.
I'm still hoping that someone will chime in about the encryption issue. It would really suck if I spring for new scanner and they start encrypting more, or all. Anyone care to hazard a guess or prediction? Why would they NOT use encryption all the time if they have the option?
Thanks,
Jack007
I am right around 67th Street and Pflumm Road, also in Shawnee. I currently have my Radio Shack Pro-106 doing all my digital work, Johnson County and KSICS. I am having problems with KSICS right now, still tweaking my programming. The Johnson County system is received clearly 98% of the time. The other 2% is motorboating or just very choppy, in and out, transmissions. I always have the ECC and Shawnee PD on. Usually also listening to Lenexa and Northzone of the Sheriff's Office on this system. I plan on adding a Radio Shack Pro-197 (or the comparable GRE) within the month of November.
All of my current scanners are Radio Shack, never had a problem that I could not fix myself or that was not an error in my programming. I have heard nothing but good things for the GRE and Radio Shack Scanners on this radio system.
I do have a non Radio Shack 800Mhz antenna that I use constantly. Cannot tell much of a difference between it and the stock antenna when I am stationary. As soon as I go mobile in the car the 800Mhz seems to be able to pull in the signal more constantly then the stock antenna.
Everyone that I have talked to about encryption has told me the same thing, basically what is currently in use is here to stay until the system is reevaluated mid 2011. The agencies that are using encryption right now plan on keeping it and the agencies that are switched to this system but not using it plan on staying away from it. As for Overland Park and Leawood, who are yet to switch to the system, it remains to be seen how much, if any, encryption they will elect to use.
The encryption on the secondary channels seems to be more of a public privacy issue, more then one of officer safety. All the agencies have ways to communicate without using the radio's if it is an officer safety concern.. Nextel's. The Sheriff's Office encryption is pretty self explanatory, in my opinion at least. They do not want to give out any information that is going to compromise their investigation while still having the ease of use and communication that the radio system provides them with.
