Johnson Messenger Two - Inline Fuse Question
KtulaRadio
Ok, so this radio calls for 2 - 2amp 250volt fuses, and I'm not sure if I need to get "fast acting" or "slow blow" type. The fuses are inline and in the actual plug. Any info is appreciated.
jassing
Shelton, WA
I always err on the cautious side... Fast blow.
If you find the pop when transmitting or high modulation, switch to slow blow. Don't ever go with a higher amp fuse...
That's how I would approach it (and knowing nothing about the radio)
Molena, Ga
That radio came with 2A 125V fuse on each leg for 120v use when they came out, slow blow fuse. 9a 32v for 12v use, 20a 32v for 6v use. Sams photofact CB-5
