To correctly answer the initial question, the best suggestion would depend on the type of scanner used. If the scanner is a handheld, I would suggest that the jumper be fabricated with high-quality RG58 coax (assuming 10' or less) or possibly even cable that might be a bit thinner. This, of course, would be to minimize stress on the fragile antenna connection on the handheld and better allow for scanner adjustments.
If, on the other hand, we're talking about a desktop/mobile scanner, there is not as much concern for the antenna connection on the scanner - as long as the weight or stiffness of the cable is not pulling the scanner off the desk. If this might be the case, I would suggest a jumper fabricated with LMR240 to preserve as much signal as possible, while still remaining more flexible and much less heavy than LMR400.
