Jumper selection (Radio to Antenna)
n1das
Nashua, NH
Yes, everything is SO-239 and PL-259 except the meter came with N connections and adapters
I think you're getting bit by SWR caused by connector mismatches on the short cable runs. The length of the cables then becomes very critical.
You could try using an N-female to PL-259 adapter on the radio and the jumper between the radio and meter have N connectors at both ends. Also try the same trick for the jumper between the meter and the bulkead.
srbecker58
Amherst, NY
Well, I took everything out from radio to bulkhead at the wall and installed a single 4' run of RG-8X and still getting good reports from people on the other end. I plan to run like this unless I experience problems at which point I will test with the SWR meter, but for now, it is not installed and everything is going well.
