- Joined
- Mar 22, 2009
- Messages
- 30
Hello.
I have owned a PRO-95 for many years, and did some research before buying a new scanner. I saw the Radio Shack sales for the PRO-160 and PRO-163, so I looked for compare/contrasts of those two scanners. It seemed that the consensus was that the PRO-163 edged out the PRO-160. I'm not sure why, but it seems like the differences between the PRO-160 and PRO-163 are:
1. 2008 model vs. 2006 model
2. 6-line display vs. 4-line display
3. 20 banks of 50 channels vs. 10 banks of 100 channels
4. Signal Stalker I vs. Signal Stalker II
5. No signal strength meter vs. signal strength meter
So I walked into a Radio Shack to get the PRO-163 when I saw the PRO-164 sitting there, at the same price of $169. It's supposed to be the same scanner, just in a handheld form. So I picked up one of these, plus the cable (which I also needed for my PRO-95, since my latest computers don't have a serial port).
When I got home, I bought Win97 (I already have Win95), copied the pre-programmed files off the PRO-164, then upgraded the firmware to version 1.06. Then I copied my programming from the PRO-95 to the PRO-164 (copy and paste back and forth).
Then I set the two scanners up side-by-side, and I was a bit surprised. I wasn't using the stock antenna. I have both the Radio Shack center loaded antenna as well as the indoor scanner antenna. I also have a Ramsey Active Antenna AA7C to boost signal strength. I was switching back and forth between the RS center-loaded and Ramsey active antennas.
First, the sound was much cleaner from the PRO-95. The PRO-160 seemed a bit distorted. Second, the PRO-95 was picking up so many more frequencies than the PRO-160, which surprised me. The PRO-95 was getting the following that the PRO-164 was skipping right past:
1. CHP in the 24 range. It would get local (within 10 miles) but not further away (30 miles). For instance, the PRO-95 was picking up San Jose and Redwood City, while the PRO-164 was only getting Contra Costa county. With the PRO-95, I can also get Marin and Napa counties, too, and even Solano and Tracy.
2. Medical in the 900 range.
I could have kep going with the testing, for aviation and such, but that was enough for me to know that the PRO-95 was doing fine. The only trunking around here that I know of is Alameda County, and I don't know if they rebanded yet (I don't listen to them anyway).
So I'm thinking of returning the PRO-164 in the next day or two. Is this a mistake? Did I buy the wrong radilo to begin with? Any advice on next steps?
Steve S
Steve S
