event3horizon
I've just getting used to this nice scanner. I'm not a scanner newb I've setup analog trunking before but this is a bit different.
I've got it though, my area has APCO-25 and I chose APCO-25 auto on the TSYS setup but I was wondering why I wasn't getting anything. So after looking, turns out my area uses mixed digital analog and that I need to set the system to 800/900 MOT. And it worked!! now I'm learning talkgroups and scanlists so it's all good.
My question is, sometimes when it's scanning, it seems to get "stuck" on a talkgroup even though there's no transmission. And when it scans, it justs "flickers" from scanning to some talkgroup and back and forth. But this happens sometimes. My signal to the control channel is 99 percent. I've tweaked squelch with a bit of success but again, intermittent success. Also, sometimes while scanning it goes from DG to VC, DG to VC, and there's static. Even though squelch is almost closed. Weird!
How can I "stabilize" this stuff? Any options to tweak/check?
I'm scanning sarasota county public system, FL by the way.
