Just got bct15x programming help
scannernut09
Bruning,Nebraska
Ok i just got the bct15x and i need help programming it off of proscan. I would click on the boxes for the county and i would click import and nothing will happen can anyone help me?
ProScan
Software Provider
Ontario, Calif.
Did the tree (the white area on the left side) populate with data? Click the "Retrieve Data" button and the tree should populate.
Are the items that you want to imported have a check in the check boxes?
After clicking the import button, close the import dialog and there should be the imported items in the database.
ProScan
Software Provider
Ontario, Calif.
Yes it did thank you proscan. Does anyone know were i can upload these frequencies into this scanner besides were it says state of nebraska?
Not exactly sure what you're asking. If you're asking about uploading data to the scanner from the database, click the "Upload" menu item.
softlad
lincoln,united kingdom
BCT15X import help
Hi,
I have just bought a bct15x and having a little trouble importing a database to the scanner. When I click database then on import from radioreference and i logg in and then click on united kingdom then nothing happens. I have used this service before on my old scanner but now cant seem to get anything. Can anyone help??
W8RMH
Feed Provider Since 2012
Hi,
You should ask this in a new thread. The thread you posted in is five months old. This is thread hijacking and is considered inappropriate.
