Yes, thank you for your posting. People are going to challenge me and think its me or my two radios that I have and have had in the past and think I am a Uniden hater.
There you go. Other people having these issues too.
I did a bit more work to confirm the issue and measure the noise. The 536 was powered with a 12V battery, no antenna was connected, and initially no external speaker was plugged in. With the bottom of the radio up to my ear (where the internal speaker is), I could hear the digital noise. It wasn't as loud as with the Motorola speaker but that seems to be just the difference in speaker efficiency.
The same test with a BCT15X had a barely audible noise floor, substantially lower than the 536.
Back to the 536, I plugged in the Motorola speaker mostly to get access to the audio output terminals of the scanner. On an oscilloscope the noise seemed fairly broadband, about 10 mV P-P, with a 100 kHz component visible when I changed the scope sweep rate. A much lower frequency negative pulse was noted at slow scope sweep rates.
Measuring the BCT15X with the scope yielded noise at 1 mV P-P. It appeared to be broadband without the pulsing present in the 536.
My 536 is about 10 times noisier than my BCT15X.
