Just ordered a New 346XT from Scanner Master
mrkelso
NNJ
Scannermaster has free ground shipping and i have wanted this model since it came out, So i pulled the trigger.
Will my programming cable from my 996XT fit the handheld or will i need to order a cable?
RoninJoliet
ILL
The same type cable will come with it...You should check the firmware and make sure it is the newest - 1.0.5 as it will fix a problem on Custom Search with rebanded Motorola trunk systems where you get NO audio and you will also be able to see the new feature of Radio ID's....
mrkelso
NNJ
I have had this scanner for several weeks now. It could have used a better antenna on it but all in all not a bad machine.
