Just passing through...I-80...who patrols?
HowD
Ozaukee County, WI
Greetings.
I'll be driving out to Milwaukee soon, which will put me into PA for the whole stretch of I-80. Is there a particular agency that patrols there? I'd like to have the scanner set up before I head out.
I should be passing through:
Delaware Water Gap
Stroudsburg
Hazelton
Berwick
Sunberry
Lock Haven
Clearfield
DuBoise
Brookville
Mercer
Thanks for any information you can provide.
radio3353
I-80
Whenever I drive I-80 I only see PA State Police patrolling it. I can't help you with frequencies, though. Sorry.
Bob
mshumeyk
Southern New Jersey Shore
The Pennsylvania State Police are still using their high band system. I cut and pasted my ARC 250 file below. The 186.2 refers to the PL. Along I-80 each county is patrolled by the troopers from the barracks from that county. Swiftwater patrols the easternmost section and uses 155.67 base 155.91 mobile. I put all the frequencies in the scanner when I travel in PA.
The 800 digital system is apparently not used for dispatch yet. They are constructing centralized dispatch centers and are some time away from completion. They are using the system for MDT's. (Details posted on the PSP website.)
Mark S
0154.7550 PSP M to M Off 2 Off 186.2 Off Off NFM 5.0
0155.5800 Channel A Off None Off 186.2 Off Off FM 5.0
0154.9500 Channel A Off None Off 186.2 Off Off FM 5.0
0155.6700 Channel B Off None Off 186.2 Off Off FM 5.0
0155.9100 Channel B Off None Off 186.2 Off Off FM 5.0
0155.5050 Channel C Off None Off 186.2 Off Off FM 5.0
0155.8500 Channel C Off None Off 186.2 Off Off FM 5.0
0154.6650 Channel D Off None Off 186.2 Off Off FM 5.0
0158.9100 Channel D Off None Off 186.2 Off Off FM 5.0
0154.6950 Channel E Off None Off 186.2 Off Off FM 5.0
0156.1500 Channel E Off None Off 186.2 Off Off FM 5.0
0154.9200 Channel F Off None Off 186.2 Off Off FM 5.0
0154.8300 Channel F Off None Off 186.2 Off Off FM 5.0
0155.4450 Channel G Off None Off 186.2 Off Off FM 5.0
0155.4600 TAC 1 Off 2 Off 186.2 Off Off FM 5.0
0151.4900 TAC 2 Off 2 Off 186.2 Off Off FM 5.0
0159.0750 Turnpike Off None Off None Off Off FM 5.0
0159.0450 Turnpike Off None Off None Off Off FM 7.5
0159.0000 Turnpike C to C Off None Off None Off Off FM 5.0
0155.4750 National Off 2 Off None Off Off FM 5.0
