tvining
Before I invest 10K in new radios, I need to validate that this configuration:
L30KSS9PW1 N
APX7500 SINGLE BAND VHF MID POWER
G806
ENH: ASTRO DIGITAL CAI OP APX
ENH: CONVENTIONAL OPERATION
ADD: AES ENCRYPTION APX7500
ADD: LIMITED FRONT PANEL W/CLOCK/VU
ADD: AC LINE CORD US
will allow me Analog Tone Remote operation by this controller interface:
<PDF MANUAL>http://www.connectsystems.com/products/manuals/Siemens_V203.pdf
Manual text:
selectable.
This version of the Flex series Universal Controller has separate
single ended and balance input and outputs. The balanced input and
outputs can be configured for two wire full duplex or half duplex
operation or four wire balanced audio allowing the user to hook up
to a simplex radio or hook up to a duplex radio operating in
either the half duplex mode or full duplex mode. All other
hardware features of the product remain the same as the previous
version of the FLEX SERIES UNIVERSAL CONTROLLER. The balanced
audio is on a separate four terminal screw type of barrier strip.
The rest of the signals are on a single ten position terminal
The EIA tones will have the following levels preset at the
factory:
High level Guard Tone 10 dBm (2.4500 Volt into 600 ohm load)
Function Tones 0 dBm ( .7750 Volt into 600 ohm load)
Low level Guard Tone -20 dBm ( .0775 Volt into 600 ohm load)
L30KSS9PW1 N
G806
Manual text:
selectable.
factory:
