just wondering if i need to
Richardneu316
Peebles Ohio
i just order 1 of this one Psr600 Digital Apco-25 Triple-trunking Base/mobile Scanner do i need to program it to get the Ohio MARCS TGID=10696 if so how do i
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Ohio data is in V-Scanner 15 and 16 but MARCS is not listed in either folder. However, MARCS will soon need rebanding down 15 MHz from 866-869 MHz grouping.
By far software is easiest method for programming but a 1 page Programming Shortcut for scanner can be found using the link below my signature.
Softwares available in alpha order:
ARC500
PSREdit
ScanControl
Win500
fmon
Eclipse, Virginia
Thanks but it looks like you need to be a genious to be able to program it lol
In RR Database for MARCS look next to Zone 6F16 for three Adams county towers. Using the Programming Shortcut, enter the Red and Blue frequencies for towers Peebles, Blue Creek and West Union--a total of 6 frequencies. The TSYS should be Default MOT 800/900 and Scanlist is default 01.
After entering the 6 frequencies you should be ready for Save out at step 13. Ignore step 14 because you will enter TGRP objects. Continue step 16 through 20. The database has 4 Adams Co talkgroups but many other talkgroups are listed in other areas above Adams grouping.
Keep the shortcut for later use when Ohio rebands the system. I.e. the bottom has a Setting T Tables for rebanding.
