Ok thanks. So to use those frequencies I would need a radio capable of picking up a trucking system?
"Trunked." Also, digital P25 Phase 2 simulcast. Currently the SDS100/SDS200 from Uniden is the only radio that has that capability. Either that or a Unication receiver. Other radios can receive simulcast broadcasts, but results are generally hit and miss, unless you setup a fixed directional antenna. The SDS series, on the other hand, is designed to operate in the simulcast environment.
Phoenix Fire K-Deck is digital and A-Deck is analog.
Welcome to the forums, BTW. A lot of great help here. All you have to do is ask.
I moved here 7 years ago and didn't know anything about the radio systems here. I have learned a LOT from the users here.
