BC536HP Programming Recommendations
Hello everyone. Relatively new to the KC area and currently have the BC536HP to monitor the MARRS system. Scanner is currently down in the northern Cass County area, and is hooked up to an outside scanner antenna. Current interests include scanning/monitoring all Metro area fire depts in the six county system. In terms of programming, I've taken the following approach:
a) Individual favorite lists for each county (separate quick key for each)
b) KCFD programmed on a dedicated favorite key
c) Individual talk group/dept assigned to the closest county simulcast frequencies (other simulcast sites deleted to avoid multi-site signal distortion).
d) 700/800 MHz band defaults set to FM
Above said, I still have had no luck picking up anything from Wyandotte, Johnson, Clay, or Platte Counties. KCFD transmissions are sporadic at best given the amount of activity the dept normally is inundated with. So my question is, should I re-install the other simulcast site frequencies? Should I leave the 700/800 MHz band defaults set to FM? And finally, is there anything I can do to help "fine-tune" the scanner to pick the MARRS transmissions up more frequently?
Thanks in advance for your help!
