Kd8azn / wqjb378
deeplist
Auburn, Indiana
BOING!!!!!!
I'm looking for a power cable for a 100 watt Orion - got one?
I have 11 cables in stock, but I can't let any of them go because I have currently have 19 orions and I keep at least 1 cable for each radio... or at least try to.
I do however have a "pigtail" cable, if you wouldn't mind splicing your own wire on it. The connector is still perfectly good and it's for the 100 watt units. I'd let it go for a little bit of nothing.
Ref----> http://pics.deckerservices.com/image_files/2012-04-12_22-21-11_293.jpg
ScanWI
MN & WI DB Admin
Wisconsin
You are defiantly ready for anything, as long as you have the batteries to back the HT's up. :)
EC-7
Saginaw Co. Michigan
If you want to get rid of stuff cheap, I could use some VHF conventional radios and 800 & 460Mhz EDACS for scanner feeds. Im running out of scanners.
deeplist
Auburn, Indiana
Yeah, the batteries along with all of the chargers are all boxed up on another shelf. It was too boring of a picture to post here as I was only limited to 5 pictures.
