Keeping Orion and M7100 on with no control head
timkilbride
Linn Co Iowa
I'm trying to utilize some radio's laying for a receive only application, but due to a shortage of control heads, I'd like to use the radio's without a control head.
On the Orion's, the radio will keep working after removing the control head while the radio is on. Once it loses power, it will never turn back on with 12v. I have tried ignition sense(pin 24), Pin 25, and the main power. Put the head back on and the radio turns back on. Is there any way to trick the radio into thinking the control head is there? The radio is powered through pin 25 so the radio is always on regardless of on/off switch position when equipped with a control head.
The M7100 will run for weeks at a time with no control head. Power cycling as no effect on it. Once it wants to stop working, a quick power cycle will not restore the radio. Once plugging the control head back in, the radio will work again. This radio is also powered through pin 25.
Any suggestions?
Tim
Radioman96p71
Pin 14 is the CTR ON signal, put that to ground or short it to pin 12 to power on the radio. It is the contact that gets open/closed when you click the volume knob on and off on the control head.
ElroyJetson
Let me look around. I think I have an extra control head or two that I can give you a really good price on.
The power-up sequence really requires a control head. A command has to be sent from the CH to the logic board and you're not going to replace that with a simple voltage input.
I'm surprised the radio will run once the CH is removed while running.
