Keeping radio on all the time ?
paranoia11
ME
I leave my scanner running 24/7 and now that I have my new SDS 200 ,I was wondering if I should start shutting it off when not around I/E sleeping, out shopping, or just out side.
Would like your opinion on this, by the way my older scanner a 536 I have kept running since I purchased it several years ago.
Remington12G
GØT AES?
I always kept my 325P2 on without issues. It ran for about 3 months straight for logging an unknown system. Never had an issue, two way radios are a different story of course.
ofd8001
Louisville, KY
I'd say the scanner was designed to be left on continuously. Look at all the things they do to allow folks to listen to their scanner via the internet. The only thing that can't be done remotely is power the scanner on/off.
belvdr
On a 200, it is possible with other gear as it has a physical power switch.
Remington12G
GØT AES?
I forgot about the feed providers, I run mine off of DSD+ so i forgot about actual scanner hardware. Anyway @paranoia11 you've got your answers. Hope it helps (y)
paranoia11
ME
Thank you for all the reply's you all pretty much say what was my opinion also.
n1chu
Farmington, Connecticut
I wouldn’t leave the display on all the time, instead set it to come on when a signal is present... or turn down its intensity.
paranoia11
ME
I don't want it to end up like my 536, turning down the display and having it stay dim, because when I turn up the the display of the 536 it never got bright again.
iMONITOR
Silent Key
S.E. Michigan
Some early generation 536's had defective displays that Uniden will replace. Most likely you had one.
