KennerPoliceTransmissions
My PRO-96 was programmed for JPSO and the KPD but the JPSO seems to override the KPD. I cannot get it to where I can listen just to the KPD. Is anyone in the Kenner area able to listen to the KPD as it once was months ago on my PRO-94 when you could hear all of the dispatched calls? They say the KPD is having trouble but is that affecting the scanner from listening to their transmissions.
Thanks to anyone's assistance.
INDY72
Indianapolis, IN
From what has been posted,.. KPD is using the JP DTRS and can be heard on it still.. eventually the KPD system will be digital and they will use it again.. any news on the FDK?
LarrySC
Greenville, SC
You must not be using WIN96 software. You can program each service in a seperate bank and just put in the ID's you need for each. "OVERride" is not the problem. The problem is in the programming. Good Luck, Larry
