Kent County Radio Issue
Brettame5
I've programmed all the frequencies I possible could have for Kent County Michigan in my radio that is on the MPSCS. The only thing I've heard is 41AMRDISP. I have not heard any Fire or other EMS agencies whatsoever. Could anyone help me on thIS?
gpp10x
MI
Thanks. I'm not familiar with the programming for the BCD scanners but someone on here should be able to help. My first thought would be simulcast distortion. I know law enforcement is encypted.
BSchaner
Michigan
Double check the tower/site you are connected to. Make sure it is 3/47 for the kent simulcast. As mentioned Law is encrypted but I hear plenty of fire talk along with the Gerald R Ford Airport.
Maybe also check to see if the scanner is not set to listen to fire dispatch and fire tac/talk TGIDs. I know the SDS models have fire talk/tac off by default.
