You will need to install the Uniden driver to be able to communicate with the scanner.
If you are having problems installing the drivers, see the following general instructions (some steps might differ slightly, depending on your specific operating system).
Download and unzip the above driver.
- Plug in the scanner using a USB cable.
- Right click on the Windows Launch icon (bottom left corner) and select "Device Manager."
- The device shows up with a yellow triangle.
- Right click on device and select "Update Driver Software."
- Select "Browse My Computer for Driver Software."
- Navigate to the folder where you have unzipped the above driver.
The driver installed and is assigned as: Uniden Serial Port (COMx)
(x) will be replaced with the actual port number.
If you have any doubts about that link not being secure, this is what I use on my computer.:
