Kenwood 710g beconing,but no packet.
Handyheather
Palermo Maine
My radio IS beconing,but not sending packet data on APRS. I'm not showing up on APRSfi or other radios. We have matched all settings with same exact radio. No luck. It was working fine before this issue.
KE5MC
Lewisville, TX
I know on my pre-'G' version without a GPS fix it would not beacon. Maybe the G version does not have that default type of lock-out so you don't beacon without a good position.
R8000
Very Low Battery
Just trying to rule out the obvious, is your radio within range of an igate ? The igate will be the device that actually converts your RF beacon to the internet and ends up on aprs.fi.
n5ims
I agree. You can beacon all day long but if you aren't in range of an iGate you'll never show up on aprs.fi. Here are a few other things to check:
1. Are you sure that you are actually transmitting a beacon and on the right frequency? I've seen some folks that have their radio set for either a + or - offset instead of simplex so their APRS beacon wasn't actually transmitting where anyone is listening for them. In the US, nearly all APRS beacons are on 144.390 MHz in simplex mode. Tone is not important so for most folks it should be turned off on both transmit and receive (when traveling some advise setting a 100.0 tone so others can call you after seeing your beacon and have you move to a simplex frequency to talk.
2. Is your radio set to APRS12 and properly configured for APRS on the side of the radio set for 144.390 MHz? There are several important settings on the radio's APRS menu that will prevent packets from being sent out. One of the key ones is "My Callsign" which if left blank will prevent the radio from transmitting APRS packets. Verify that all values in APRS menu are set correctly. There are YouTube videos on how to do this as well as several "how to" web pages that will be helpful.
3. Make sure that the radio's GPS has a good lock on the GPS signals. The radio will not transmit beacons if not locked (or your location is hard-coded into the radio). In the upper right corner of the radio's screen you should have a blinking GPS to indicate that you have a good lock on the GPS signals.
4. Check out this thread on RR (Kenwood: - Kenwood TM-D710GA Will Not Beacon Out | RadioReference.com Forums) that discusses this exact issue and provides many things to check and verify. It has helped others get their D710GA to work on APRS and hopefully it will help you as well.
Good luck!
Handyheather
Palermo Maine
SOLVED!!!
Something overlooked,I had a crimp in the power cord.We replaced the cord and boom back in.Happy that is was a minor issue and no hard reset was done!!!
KC1NKQ
