Kenwood 7180 Programming
lismacab
New Brunswick, Canada
Hi Folks,
Have programmed a few of these before and now running into a problem in trying to program this last one. It takes the data but no audio is heard. The speaker works as it beeps when it's turned on and will transmit but it's like the mic is turned off. Any suggestions?
Radioman1993
Hi Folks,
You might also want to check and see if the mic jack was programmed as a data port also. If all of that checks out or even as an easier check try a different microphone on the unit and see if that gets you TX audio.
Radioman
lismacab
Tk 2180
Sorry for the confusion I am dealing with the 2180 and not the 7180, I can program fine and it will transmit but no audio and no audio received. I can hear it if I listen faintly..Not sure what's up..Tried speaker mic same thing, when I tunr it on it beeps loud and seems to work fine that way..Suggestions
500e
UK
have you programmed in 5 tone mode ?
optional features
power on
monitor closed?
