Kenwood 7180H AUX A button?
FARMER522
Hi I have a 7180H that I just bought. When I read the programming info in the radio the square button is set for AUX A. When the button is pressed it shows the TX frequency RX frequency along with the pl tones. My Question is how do I make my other radios do the same. I have wrote the program to them and they will not do the same. Any thoughts?
kd4efm
EL98 Florida
Sounds like tactical is turned on. Click on product button after your load the code plug or read the radio, should be checked or unchecked.
KD4EFM EVANS
sent from my HTC m9
FARMER522
I checked that and it is not checked for on. The firmware version is 1.17 checksum CCO3. Also triangle button is set for Display Character and when pressed it just beeps with no change. Forgot to mention when I push the square it shows 1- 1 push agin RX frequency push again TX frequency again then the pl tones and again back to the name for the channel.
kd4efm
EL98 Florida
That's under key assignment. So yes, that's what it should do.
KD4EFM EVANS
sent from my HTC m9
kd4efm
EL98 Florida
Let me do some research and see what 1.17 CCoh3 is (or CC zero 3).
I have in my repository 1.19 and 1.22.
Where did you get the radio from? Does it have direct entry like 01-01, 61-61
Does it have Railroad frequencies in it? If so then that explains why it does what it does.
I'm not a freelance user, I am systems designer and field service tech. I have vast knowledge on
the TK-x180 line as I spent the last 6 years working on them.
Please provide more information.
FARMER522
The radio came from Canada and I think they maybe railroad frequenices. What does that mean?
