when I key the mic the radio shuts dowwhen I unkey the mic the radio comes back on, new mic same thing. Same power souce for a year nothing new.
If you have a
TK-8180, it needs, at minimum, 9 amps at 13.6vdc to function properly when transmitting at high power. If running at low power, it needs at least 5 amps at 13.6vdc.
If you have a
TK-8180H, it needs, at minimum, 13 amps at 13.6vdc to function properly when transmitting at high power. If running at low power, it needs at least 8 amps at 13.6vdc.
If your power supply is not capable of providing that amount of current at 13.6vdc, the radio will absolutely shut down when transmitting. It's starved for power. More power supply capacity (amperage) is OK, it won't hurt the radio.
