Kenwood KMC-45 Promo Video ... where is the speaker mic plugged into?
sefrischling
Public Information Officer
New London, CT
Skip to around 18 seconds on this official promo video from Kenwood regarding the KMC-45 speaker mic ... you tell me ... where is the speaker mic plugged into?
WB5UOM
You really think that is an official promo video from Kenwood?
What a circus.
But so what- it shows the mic being plugged in to the radio.....
sefrischling
New London, CT
What a circus.
I don't think you watched where the mic cord is plugged into at the 18 second mark ... and ... the video is on an official Kenwood YouTube account. Thanks for playing!
tweiss3
Is it time for Coffee?
Ohio
IRC, you can order the NX1K or NX3K with that microphone connector. Can't remember which one.
wd8chl
And that speaker-mic has been discontinued for several years now. KMC-70/72 are the current ones.
AM909
Radio/computer geek
SoCal
On the NX-3000 series, you can order the two pin or the 14 pin.
I'm having trouble finding that option anywhere. You sure? The 3x00 manual shows the 14-pin connector and the 3x20 manual (and radios I have seen) are all 2-"pin".
EWC_BDN
Any word if the new one with worth buying? the KMC-45 was pretty junky. better off buying after market.
Alarmguy
Former Alarm Guy, turned Radio guy
Deep in the heart of Jersey
The two pin needs to die a fiery death...
On a serious note, you actually loose some Bluetooth features on the two pin version of the NX-3000 so if you ever want to do anything with BLE...not supported on a two pin.
I hate those things. Broke 2 KPG-22 cables due to pins breaking off. NX3200 and NX3300 are the Multi pin radios.
NMO's installed, while-u-wait.
NX-3x00 is the 14 pin model.
NX-3x20 is the 2 pin model.
You order the model you want.
Like others, I avoid the 2 pin radios unless it's one of the lower tier where it's the only option. (ie: NX-1000 line)
AM909
Radio/computer geek
SoCal
Interesting note from the catalog:
Note: KMC-45 (Non D version) is not compatible with DMR (TDMA) operaiton.
which is weird, given the non-D version is no longer in the catalog (and presumably not orderable). I guess they're saying you can't re-use your old 2-pin mics when you "upgrade" to DMR.
A similar note is on the KMC-9C desk mic, confirming the KMC-59C note that says:
Note: Compatible with FDMA (analog / NXDN) and TDMA (DMR) Operation.
Anyone know the details of the reason?
It had to do with the pulse rate of DMR getting into the audio on the portable radios. Needed some extra filtering.
Not an issue on mobiles where the antenna is physically separated from the radio.
From the NX-3000 function reference manual:
To use Portable in a DMR Conventional system, always use KMC-45D. Burst noise may occur if an external microphone
other than KMC-45D is used.
n7maq-1
Oregon
The mobiles did have the same issue, that is why the switched from the KMC-35 to the 65's.
Jim
EWC_BDN
Motorola PMMN4013 had the same issue. Older ones don't play nice on DMR. The updated ones have a square wave on the connector meaning that it will work with Digital radio.
In case anyone was wondering why that square wave was on the those connectors.
