Kenwood KSC-24 Charger
kg4uad
Pickens, SC
. . .Red is charging, green means it is done charging, but what does flashing green mean?
TIA,
Tim K.
How old is the battery pack? Sounds like either your battery pack is getting well aged or the charging cradle has an issue. Charging my tk-270g' s KNB-20N takes about an hour from full discharge, if your charger is taking longer than that you might have a problem. Does the red light ever come on?
kg4uad
N1SQB
Somewhere On Earth
Not a battery issue!
I will put in a call to my local dealer. I have 2 of them. I use them for my TK-380 UHF portables. I have 2 new 2100 Ma batteries. It does the blinking thing with both on both chargers.. Its always done that so I just thought it was just how it was suppossed to be. HMMM!
Manny
timkilbride
Linn Co Iowa
kg4uad
Battery pack is around 4 years old. Charging cradle is new. My battery still lasts 12 hours on one shift for the railroad. The red light comes on, then blinking green, then solid green.
Grog
Banned
West of Charlotte NC
This is only a guess
In that instance, it sounds like the charger might be saying the charger has switched from rapid to a trickle to finish charging the battery, like maybe the last 10%?
How long is it in red, then flashing green modes before going to solid green?
K9UWI
Retired LEO
EM58mh
I have had this particular model charger for just over a year now and have yet to experience this issue. I tried a number of things in an attempt to create it but had no success. I will be anxious to read the explanation provided by the dealer.
timkilbride
Linn Co Iowa
Did anyone find out anything? My batteries are still working great and I'm still getting the red light, then green blinking light, then a solid green.
TIA,
Tim
Resdon111
Sorry for the necro on the thread, but did anyone find an answer for this? I am having the same problem.
jshep26101
ksc 24 charger
I was looking in my manual and it says a red light charging a blinking red is that the battery is no good a green is that is completed charging, it didnt say what a blinking green means
cybercat32
Nepean ON Canada
blinking green
Blinking green means you are almost fully charged and the charger has switched to a lower "trickle charge" state to finish things off.
krokus
Southeastern Michigan
I haven't looked at that model's info, specifically, but typically indicates battery is being "topped off" in a trickle charge mode.
