kenwood ltr system question
captaincab
monitoring delco pa with gre psr300 pro2053 and b
what is needed to program a kenwood radio on a ltr trunking system besides the home channel assignments and talk group info of the talk group i want to be on this is a non public safety ltr vhf system used by several local cab companies. of course i know i will need the software and cables but from what i understand kenwood software is easier to buy than other brands from the company.
domes
You need the address of the shop that operates the system so you can get their permission to use the system and properly program the radio for you. LTR is a simple system but not that easy to "guess" the programming. Just because the system may be licensed for 5 channels doesn't mean that the repeaters are numbered 1 - 5. They may be randomly be numbered 2, 4, 7, 11, 19 so when the system tells your groups radios to go to 11 you have to have the correct freq programmed into your radio's ch 11 position. You also need to know if the system is inverted or not. These things are done to prevent false signals from other nearby LTR systems but also to frustrate bootleggers. (not pointing fingers). If you are trying to work with more than one group with different home channels then you may have to program them in separate zones. The system might also be a PassPort or PassPort type protected system so you might need a LTR radio with imbedded PP-ESN or option board and you will also need PP-LTR software to program the PP functions and the ESN will also need to be activated on the system. Most LTR radios are pass word protected so you probably won't be able to read another radio to duplicate the information. There are other reasons why you need the system operator to program the radio.
R8000
Low Battery
Without this permission, your committing theft. Radio shops who own SMR's do it for profit and charge a monthly fee to use their systems. If your having to ask this question, then you didn't obtain permission otherwise they would have programmed the radio for you.
If you just want to monitor, use a LTR capable scanner. Life will be much easier this way.
Just a FYI , SMR's can run GW3 which gives a very detailed view of their trunking system. On Smartnet and digital trunked systems, you can have GW3 automatically inhibit (kill) a suspect invalid radio.When that happens your radio is dead in the water.
captaincab
thanks for the info i have the home channel info and talk group id's but it sounds like i need alot more info than i have. the reason why i want to know is i own 12 cabs in philadelphia they are spread among a few dispatch associations i currently use a spare radio for each system i keep for when a cab has radio issues to monitor the cabs but it can be a hassle 3 radios all with power supplies and antennas etc set up was trying to simplify things the radios i have now are used as spares and do have identifers on the system and the radio guy who services most of the system knows how i use them and i do pay for each radio monthly to the system owner so i am not persay trying to cheat the system just make things easier
R8000
Low Battery
Good to hear your not stealing service !
I'd ask your vendor to provide the settings you need. If all is well between you and them, then it shouldn't be a problem.
captaincab
thank you r8000 and is the programming simple once i get the settings and stuff i have programmed motorola stuff for my private use in ham radio and my use as a volunteer in the public safety field as well as for my volunteer fire company and before anyone asks yes i own my motorola software legally monster license agreement and all
KevinC
Other
Super Moderator
Home
Your profile states you are a tow truck driver???
And you asked the same question about 7 months ago...
http://forums.radioreference.com/kenwood-forum/266517-need-info-ltr-system.html
...which is frowned upon.
captaincab
as for the double post i appoligize and i do drive a tow truck gee i was not aware having family in the cab business and owning cabs meant i couldn't list my day to day profession as a tow truck driver since that is what i do as far as work as my cabs are all leased out but i will change my profile to reflect both careers
KevinC
Other
Super Moderator
Home
You don't have to change your profile. I just happened to notice it said one thing but your post said something else, which could lead people to believe you are being less than honest.
