Kenwood MDC
sfd119
Couple Kenwood questions.
First, can I enable MDC on all analog channels or do I have to check it on each and every channel?
Second, can I copy my MDC ID list to another Kenwood codeplug or do I have to retype it in on every new codeplug.
Thanks.
Hiding in a coffee shop.
I don't know about all the Kenwood radios, but the MDC is turned on in each personality on the TK5x10 hand held radios.
I've never used MDC id lists, so I've never done it, but try doing a right click and see if you can cut-n-paste it.
ramal121
Lots and lots of watts
Calif Whine Country
Most MDC functions become active in a zone when the zone is set for that mode. The only thing that is on a per-channel basis is PTT ID encode.
Once you fill out the ID list you're set to go for multiple radios, just clone them. The only thing that you have to do is change the "OWN ID" before each write.
sfd119
The problem is I have three codeplugs for an agency. If I add an MDC ID to Codeplug #3, I must add it to the other two. How can I copy them? Motorola I can drag and drop.
As for the MDC per zone, I'll have to look at that. Right now I can turn it on a per channel basis...but in my scenario it'd be easier to just do it on a Zone Level.
ramal121
Calif Whine Country
Yeah sorry, no drag and drop between codeplugs like Motorola. Nice feature though, wish other mfgs would adopt.
You may want to explore import/export to see if that would help you. Check the help files in the software.
What MDC features are you attempting to enable. Some are automatic on all channels when the zone is set for MDC. PTT ID encode is set on a per channel basis, no way around that.
Sent from my Nexus 7 using Tapatalk
sfd119
That's what I figured. When I tried import/export it wouldn't let me "copy" the MDC ID list across.
I'm just enabling Post PTT MDC ID across two channels right now, but eventually, it will be on all analog channels for accountability purposes. Just wondering if there was an easier way.
Thanks.
Stealthguy05
Do the Kenwoods do the Data Operated Squelch muting like the Motorolas do?
