Kenwood Mixed Mode System Talk Group
Rlahey
Sunnyvale Trailer Park, Dartmouth, NS.
Hello- with Motorola system programing when setting up a mix mode personality you can set the radio to NOT pick a talk group. In the Armada software when programming a mix mode channel I cant find a way to NOT have the radio pick a talk group, other than talk group 1 with an ID of 1. Im guessing that most systems default to an ID of one, even if they aren't using TG's on that repeater, but I cant confirm that as Ive never ran into this issue previously with motos. Is there a way to have the radio not use a TG on a mix mode system?
otobmark
NC
With my Kenwood/EFJ radios using a talk group of FFFF will open on any incoming TG (talk group equivalent to nacf7e) and outgoing opens all other radios (all call).
I’m not sure any radio can actually send P25 without a TG. The default TG 1 is what all my receiving radios show when TX radio appears to be set to No TG on radios that permit it.
wd8chl
Talkgroup 1 is the same as none
No, it's not. It TG 1.
I ran into that problem with NX-3300's at first, putting them into systems that had Vertex EVX series radios. The Vertex's all defaulted to TG 1, and the KW's defaulted to no TG, like they do for NXDN. They did not talk to each other, so I had to re-program and put TG 1 into all the KW's.
tweiss3
Is it time for Coffee?
Ohio
I was curious last year and did a bunch of P25 testing between my NX-5300, Xg-100p and XTS-5000, and none of the cared if it was TG0 or none. I don't have any Viking line radios, but I was assuming it is the same (it wasn't mentioned above, but I can assume the question was about P25, not DMR).
NX-3300 would only do DMR, which is picky between talkgroups.
otobmark
NC
When I put TG 0 in my VP8000 the channel became “Receive Only”. So far for me TG FFFF is as close to CSQ as I can get in P25 (293 TX and F7E RX NAC). I don’t think there is a broadcast or ALL CALL TX NAC…
tweiss3
Ohio
TG0 is an all call and can only be transmitted from a console, thus the RX only.
