Kenwood nexedge
chief21
Summer - Western NC; Winter - Tampa Bay FL
Anyone know of frequency list for the channels of these digital radios?
Typically, commercial radios are programmed with the frequencies that the buyer is authorized to utilize. Other than certain frequencies that might be used in the testing process before leaving the factory, they do not come loaded with any usable frequencies.
craigakagravy
Thanks, so there is no way to monitor them?
The radios come from the factory unprogrammed. In fact, when you turn on a brand new on out of the box, the display will show "UNPROGRAMMED". They require programming for the frequencies the owner is licensed for.
If you know what frequency they are programmed for, they may be able to be monitored.
-There are scanners that will decode NXDN/NexEdge
-The radios come from the factory with included encryption, and it doesn't cost anything to turn it on. If the radios you want to listen to are encrypted, you can't/won't be able to decode audio.
-You can purchase a Kenwood or Icom NXDN capable radio and program it for receive only, however, if the radio is running encryption, you still won't be able to hear audio. If it's a NexEdge trunked system, it will not decode the trunked system traffic unless your radio is legitimately on the system (as in programmed for it by the system administrator)
-If you want to listen to NXDN/iDAS/NexEdge, your best bet is to get a scanner.
craigakagravy
Thank you very much for all your information.
