Kenwood NX-340 Protalk vs NX-340 Nexedge
Just bought the nexedge NX-340 and found out that they have to be programmed via cable and windows only software.
Was wondering if anyone knew of a difference between the two versions? I know that the protalk version can self program but wanted to know if there were any other differences
LATA 722
The NX-340 comes un-programmed and will require programing with the software to use.
The NX-340U-16P Protalk model is pre-loaded with some itinerant UHF channels (they still require a license).
The Protalk radios will have a different firmware than the non-protalk radios, and will use a different programming software. I'm not 100% sure on the NX series protalks, but on the analog versions, the programming software will only let you pick from the pre-loaded frequencies. You can't program in whatever you want.
Other than the firmware and sticker, it's the same radio.
LATA 722
Depends on the shop you ask to do programming.
Bench time can run around $85/hour, but this isn't bench level work. Likely it's the same tech, though. It's really best to call around and ask.
