Finally i have something to show, at the end of this post you can find a demo version to test NX5000 series radios and others Nexedge series
some of the features added to demo software are:
- Smart COM Port Detection
- Radio base Programming detection
- radio base turn off detection
- Nexedge supported
- Fleet Sync supported
- English and spanish languages supported
DISPATCH
- selective call
- status message
- short message
- remote monitor
- stun / kill / revive
- Relay activations
- get serial number over the air
- get ESN over the air
- remote turn ON / turn OF detection
- virtual Radio Keyboard control
- create users with different privileges levels
RECORDING
- call recording
- calls search
- merge audio files
- answering machine
- note creation
- call log
- flexible alert creations
GPS
- Street View
- poligonal Geofences
- Speed limit
- Placemarks
- flash back
- GPS Log
- detailed address
- get closest distances between event point and radio units
- radio isolation
REPORTS
-calls analysis
i recommend windows 7, but windows 8 is also supported
INSTALLATION GUIDE
for installation just copy Tucson, records and lib folders to C:, also copy Dereck.jar to C:
run Setup file and that's it, finally install Tucson Activator and run it
you will need an DB25 - DB9 serial cable to connect base radio en PC (NX5800 & NX800 series) if you don't have a serial port in your computer use a USB - DB9 serial adapter , also you need an 3.5 male - 3.5 male audio cable in order to record calls
NOTE: special programming for radios required
Download Link
https://www.dropbox.com/s/7jsno2ymb35izb8/Tucson Installation.7z?dl=0
