Kenwood NX-5000 dual-mode P25/NXDN radios
kayn1n32008
ØÆSØ
Sector 001
If it is dual band P25+NXDN capable, all they have to do is throw trunking into the mix and I will preorder one right now! Oh, and it wouldn't hurt if they added multiple scan lists, that's a feature I've always wanted in a radio.
Uhh, it will do trunking, both NXDN, and P25...
Sent from my iPad using Tapatalk
SNCZCA01DS0
Should be interesting if these do both flavors of NXDN trunking. I suspect they will, but it would be nice to know for sure.
kayn1n32008
ØÆSØ
Sector 001
Didn't have to be rude about it, I haven't seen anything that indicated that it would do both conventional and trunked. But if it does do that, then I'll preorder one as soon as I can.
Read post 18. I was not trying to be rude. It was stated that the radio would do trunking(TDMA P25 is only available on trunk systems) and all kenwood NXDN radios I have seen will do trunking. My NX-700 will, I only use it conventional/analogue.
radio259
Pittsburgh PA
I only hope the UHF 45-520 split model will still slide down to the hammy band with no problem. This will be atough purchase to hide from the wife.
radio259
Pittsburgh PA
I hope these UHF 450-512 splits will still cover the ham band with no problem. Would be nice to get both at same time, but that might be hard to hide from the wife.
wireless_friendly
Banned
I will buy REV3, but not before. Kenwood like to change CPU and stops support of previous releases.
kd4efm
Florida
NX-5000 (some other info to add)
As some of you all know, I am pretty much in the thick of it with NXDN (ham side) and what is to come
with the NX-5000 series.
To add, the radio will do Analog LTR also.
(brian cell explosion)
So yes, once KWD is done with their little US tour on this, it will be released, 700/800 first, then VHF and UHF
models end of the year 1qtr 2015.
So recap;
700/800 (dual band), VHF model, UHF model (sorry no dual band V/U),
Modes:
P25 P1/P2 trunking
P25 Conventional
NXDN
NXDN Gen2
Analog LTR
Analog Conventional
and all the little goodies to go with it (OTAA, OTAP, OTAR, SDM <nxdn>) *not sure about P25trunk SDM
KRK-10 remote mount COMPATIBLE
Let the FOAMING begin!
Evans
KD4EFM
kd4efm
Florida
I will look into that, but since that is the now standard for ENC and FIPS, I would say yes.
EFM
EricCottrell
Boston, Ma
Hello,
Three portable versions have appeared on the FCC website.
ALH442000 NX-5400 700/800 P25 with Bluetooth Portable
K44431500 NX-5300 UHF Portable
K44431501 NX-5300 UHF Portable
73 Eric
SNCZCA01DS0
Is the difference in the UHF portables band split or is one supposed to be a VHF portable?
K44431500 NX-5300 UHF Portable = 450 - 512MHz. 5 watts. Part 90 certification. Interesting that it has a 16K emission designation for 470-512 for the T-Band stuff.
K44431501 NX-5300 UHF Portable = 406.1 - 470MHz. 5 watts. Part 90 certification. No Part 95, so no GMRS, legally…
One of 50 States
So recap;
Modes:
P25 P1/P2 trunking
P25 Conventional
NXDN
NXDN Gen2
Analog LTR
Analog Conventional
Evans
KD4EFM
Don't be surprised if the radio cost between $1.2 - $3K loaded with all the features, as you wrote above. The cost would be slightly more then a TK5210 which has a range $1 - $1.8/9K without any features, depending on the dealer.
baycomm
Greenville, Delaware
First hand from the recent road show:
Ok, but how about AES-256 and KVL-3000+ compatibility?:
YES, optional AES-256 board to be available both with & without KVL-3000+ compatibility
Note that DES encryption will be included as a standard feature.
We were told UHF release THIS MONTH (we'll see) with 700/800 to follow by end of year.
Standard config will be analog/NXDN with trunking. P25 Phase 1,2 optional via software key, 1000 channels
4000 channel option, programmable DSP noise canceling standard.
Micro SD card can be used to record custom .wav files for channel announcements.
Dual transceiver mobile kit for multi-band operation. Optional larger display control head with knobs.
IP67 submersible to 1 meter standard (You can wash it off if it gets dirty)
+many more features & options
Price was stated to be 10% over existing models. Hopefully, they meant 10% over NX-200/300.
Motorola has neither a radio that can match this nor one as nice looking.
