APX8000
Sarcastic Member
drool....I'm just hoping they can do multiple P25 trunked systems. My 5820 only does one.
Yup right there with you Mark! It needs to be an option. I can see for LE having a physical stop may be important but for fire we need to be able to expand out past 16 channels per zone using the knob not the keypad just like the 2180 radio.
Here are LIST prices:
Portables: UHF & VHF(VHF will be released in Dec.)
Standard key pad: $825.00
Full Key pad $875.00
Plus battery, antenna, charger & any upgrades that you may want.
Mobiles: $980.00 plus software upgrades if desired.
I don't yet have the 700/800 Mhz prices.
Right. Conventional P25 will be included.
Phase 1 Trunking is optional
Phase 2 Trunking is optional.
P25 OTAR, P25 conventional voting scan and P25 packet data are all options, also.
The prices assumption above is pretty dang close.
Other individual licenses:
4000 Channel/Group ID expansion
FPP option
MicroSD slot activation
Bluetooth serial port "profile"
Type C NXDN trunking (Icom standard)
Where did you get your information about the NX5000 series coming standard with P25 Conventional. The info I got says that P25 conventional is not standard and is an option.
I would love to see/hear a review once someone finally gets their hands on one.
I may wait a bit, but am definitely going to pony up
And now another flavor of amateur radio? Analog (wide & narrow), P25, MotoTrbo, Hytera flavor of DMR, Nxdn, I wonder when the MPT1327 and the TETRA systems will be up and running?
Makes great sense if you are traveling or coming into an area in an emergency situation.
The startup screen can be really customized now!
As for a previous comment NXDN Type C trunking (Icom Standard), umm no, that's Kenwoods Standard.
Icom uses TYPE D (which is like analog LTR trunking but digital)
In Bitmap File, a file name can be selected in the bitmap format which appears on the transceiver LCD for 2 sec when the transceiver is turned ON.
Range:
File name with a maximum of 20 alphanumeric characters having the extension of ".bmp".
Default:
Blank
Note:
*A monochrome image with a maximum of 180 pixels (height) x 240 pixels (width) (NX-5300/ NX-5400) or 154 pixels (height) x 422 pixels (width) (NX-5800) can be preconfigured for the transceiver.
*The selected image will be stored with the KPG-D1 data file.
*Unchecking Custom Start-up Screen disables Bitmap File.
