Kenwood Nx-5200 home channel
Baker845
anywhere
Is there a way to program the Kenwood nx-5200 with home channel radio wide? I notice the home channel option only works in one zone, can it be programmed radio wide?
Vern
Union County, GA
I use the Direct Channel functions. There are 5 and I program them to keys 1-5 on the keypad mic. They're easy to reprogram on the fly and work from anywhere in any zone. Just a thought.
Baker845
anywhere
I will give it a look, i was hoping to program it to return to zone 1 channel 1, but dont see settings to do that.
dispatch235
Central Missouri
Once you select a button for "Direct Channel" , there is a secondary function you can use to select the channel, or you can go to the Call/Direct Channel tab and select the channel and zone you want, and it will work no matter which zone you are in.
