Kenwood Nx-5200
Baker845
anywhere
Any one with a Kenwood Nx-5200 radio using a KRA-25 or KRA-28 antenna's, can tell if they work better then using KRA-26 antenna?
thanks
Not on the NX-5200, but I've used them on NX-210's and TK-5210's.
The KRA-25 works marginally better than the stock antenna. It's got a tiny bit more gain, but not a huge amount. Trade off is that it's a tiny bit narrower in bandwidth if you are using for amateur use. Our officers used those on their NX-210's for years, and other than the annoyance of the longer length, they were durable and gave us a slight edge over stock. Only had one shorter female officer that kept her KRA-26.
I've used the KRA-28, and it seems to perform the same as the KRA-26. Obviously more bandwidth, which is great if you are using the radio for ham use. But it's a stiff antenna and only the top half is ~sort~of~ flexible. Not something I'd want to carry on my belt.
I think I've been using the KRA-26 most of the time. Just not a huge performance difference.
kd4efm
EL98 Florida
I use the KRA-28 for ham (wide banded 140 to 170), the KRA-25 is more for the railroad (high end VHF)
My tests with them has been about .5 dBm better than the 26m (stock antenna)
For what it's worth, if you trying to listen to far away stuff, you have to take it off the belt
and hold the radio like the training manuals show. (just saying)
Baker845
anywhere
Trying to get idea, my fire dept, has Kenwood Nx-5200 radio's and having some issues with radio's hitting the repeater.
kd4efm
EL98 Florida
1, you will get more complaints with the pogo stick than the 26m
2, need to consult with the local radio shop or dealer that services the repeater and let them know
3, take it up the chain of command if you're not getting anywhere (politely that is)
* edit
4, need to look at getting a VRS to use the engine radio when on scene, that is specific to the main channel and not fire ground.
kd4efm
EL98 Florida
Picture of my 52 and 3200 SxS
n7maq-1
Oregon
Ok, height little bigger not much.
I used to use a KRA-25 (It's actually a Kenwood packaged Centurion EXH-155-SFK) until I was handed a Larsen SPWB22150. The Larsen performed overall just as good as the KRA-25 but it covers the full 136 to 174 and is a bit shorter, the down side is the cost. I also had a EXH-160-SFK for railfanning, but the Larsen also seemed to work just as well. Now I use a KRA-47MB :) but that is not on my 5200.
Or as Evans mentioned you can look at an vehicle repeater. We have done dozens of in-band Pyramid SVR's over the years and they work very well IF set up correctly. Shot me a PM if so, we have SVR's in both of your north and south neighboring counties.
73,
Jim
I agree with Evans.
We had some places where our VHF repeater didn't cover very well. The higher gain portable antenna did not fix the issue. It just made the places it was scratchy, a bit less scratchy. The 0.5dB improvement that Evans reported sounds about right. 0.5dB isn't going to fix anything.
wd8chl
And NOT upside down! I'd hate to tell you how many times I see PS people pull the radio off their belt and hold it upside down with the antenna pointed down and worse, their hand over the mic. And then they complain the radios are junk and we need a new system, blah blah blah...
