Kenwood NX-5800 PC interface cable to be used with KPG-180AP
eadlrm
Hi guys, I have been searching and searching on how to connect a NX-5800 to the PC to transmit the programming to the NX-3300 units. Does someone know where to find such a cable or if it has to be made? Any help and guidance will be much appreciated.
eadlrm
Thanks for the information,
Essentially a DB-25 RS-232 printer cable, do you connect it straight to the LPT Serial port card as my computer does not have one or can a
DB-25 RS-232 to USB cable be used?
kd4efm
Florida
SERIAL CABLE, not printer..
Usb to DB9, to DB25 will work.
OR DB9 to 25 cable if you have a 9 pin com port.
program the radio as per the manual shows. (transparent mode)
eadlrm
Thanks for the clairification, long time I havent seen an old printer cable and on one end it has DB25 and the other is centrix.
