Hello again everyone,
As an update to my previous thread about the NX-700K I accidentally received (instead of a TK-7180) with the wrong control head on it, I managed to get the proper NX-series control head from the same eBay seller and now the radio powers on!
Original issue thread :
forums.radioreference.com
Yesterday I downloaded the original NXDN channels data that were programmed by previous owners, then programmed the radio with a new (starting from a blank KPG page) "conventional" set of frequencies using KPG-111D v5.30 with the "Lab Patch". The frequencies include MURS, HAM, Weather and local VHF repeaters, in 4 separate zones.
Now I unfortunately have a new problem that has me dumbfounded :
I would really appreciate some guidance in what I should do next. Also, does anyone have a "stock" tuning file for the NX-700K unit? It is a Canadian version of the NX-700K which is not supposed to be restricted to Narrow band. Firmware version is 3.05, I believe.
Kenwood NX-700K No Power-on Issue
Hello, I've recently bought two "untested" TK-7180H radios, both having their harnesses cut and in quite a rough shape cosmetically (dirty + scratches). I have the Kenwood wire harness connectors and pins from DigiKey and so I made new harnesses for both units. The first unit required that I...
- The radio will not receive any of the normal channels that should be transmitting, like my two local analog weather channels and local VHF analog repeaters. I have tried two UHF / VHF antennas that work well with all my other UHF and VHF mobiles, but there's no RX on this NX-700K.
- The squelch level is set to 2. When I set it to 0, I can faintly hear the strongest local weather channel. The same weather channel comes in strong on my TK-2180 and TK-2140 portables without any issues. So, the NX-700 is most definitely not reading the signal correctly.
- When I use the portables on MURS, HAM or marine frequencies, the NX-700 is able to hear the transmission and everything is good. It can also transmit just fine to the portables. The NX-700 acts almost as if the antenna wasn't connected and only "hears" the strongest of analog signals.
- I've taken the radio apart to look at the internals. I can't see anything burnt out or any loose solder points where the antenna connects. The tiny little black SMD diode or resistor (R150) next to the antenna connector does have continuity to the radio body, but no continuity across to the antenna solder point. I'm not sure if that's normal.
- I've looked under the tuning options in KPG-111D, but it's beyond my capabilities. There are separate settings for analog and NXDN, plus a lot of them are not self-explanatory. I did save the tuning data (.tun file) of the current configuration, in case this is a tuning issue.
- I've read parts of the user's manual to find answers. There are many optional features of this digital radio that I have no clue about, including digital keys, scramblers, compressed signals, etc. Perhaps this is not a hardware issue, but a programming issue...?
