Kenwood NX-820 repeater cable
LGolder
PA
We are trying to hook 2 of these up for a mobile repeater because that's what we have extra of laying around... Is the cable for these pretty close to the NX-800 just the pins changed to match what they are on the 820s? Also these need the TTL level changed to the RS-232 internally correct?
Just a general search nets me nothing online...
Different, DB-25 vs. DB-15, as I'm sure you know. The pin assignments are different and there's settings that will need to be programmed via software.
Correct, if it hasn't already been done, and you need RS-232.
LGolder
PA
I have the pin outs for both just needed to make sure everything else was the same, AFO 17 (800) = AFO 4 (820) and I can use a FNC to replace the AUXIO IE AUXIO3 22 (800) = FNC3 8 (820) which from the looks of the programming software I can. I just wanted to check before I attempted. Thank you
n0fwg
Minnesota
I do not have a service manual in front of me, I recall that you may need to move some surface mount resistors to change the function on the pins from DEO (detector) to AFO (audio Frequency out) and DI (Direct Input) to MI (Mic Input)
Jerry
You'll need to add some components to massage the audio levels between AFO and the MIC input, but you're on the right track.
There's some chip resistors you need to move around in the radio to change the TTL to RS-232. Page 8 of the service manual. Something you want to do in a good shop with the right tools and a steady hand.
