Kenwood NX crossband audio
swwifty
I have a dual deck NX5700/5800. I bought a custom made cross over cable for it, that allows them to be crossbanded.
This setup works just fine, but I've noticed the audio sounds pretty bad. It's almost like the audio between the radios is over driven.
I haven't been able to really find any settings that adjust this, does anyone have any insight? I can provide more details on the setup if need be, but thought I'd ask more generically first.
Thanks.
tweiss3
Is it time for Coffee?
Ohio
Is it the cable from Alberta Radio? If so, there is a pot to tune audio on the DB25 connector.
swwifty
No, this was bought from a individual who made it.
Can you provide a link to that one? maybe I need a different one.
swwifty
Yep, that's the one I have. Follow their instructions and you can turn it on and off with the puch of a button.
Thanks, but maybe I wasn't clear enough. I don't have this one. I have one that doesn't seem to have any adjustment on the cable for audio levels. I'm guessing its not a option in software if this one has an adjustment?
Did you experience bad audio, and were you able to adjust it with this crossband cable? I assume so, but just want to be sure before I order it.
Thanks.
tweiss3
Ohio
I don't think there is any adjustment in the software.
ramal121
Lots and lots of watts
Calif Whine Country
The cable is going to use the receive audio (AFO) on the DB25 connector. The NX-5X00 allows adjustment of the AFO line in the software. It's in the extended function tab and you can knock it down 10 dB from the default.
To adjust the microphone input it's in the audio profile as external microphone sense and you can run that down a whopping 20 dB from the default of 0.
swwifty
Thanks I'll try that too. I also ordered that other cable from Alberta radio since it has an external TX audio adjustment as well. I figure they did that for allow for more adjustment.
Cognomen
Radioactive Zone
I built the analog cable from the schematic that was posted on this site a while back. You can add a mini pot to the audio input line on each end. I placed the pots inside the DB-25 hoods, and drilled holes for adjustment.
ramal121
Calif Whine Country
Kenwoods normally output about 200 mV RMS on the AFO and the mic input only needs about 10 mV RMS. So there is a mis-match and some balancing is required. Have fun!
swwifty
I wanted to follow up on this. I got the Alberta Radio crossband cable, and it is dramatically better than the one I had. The crossband audio is much cleaner now, and I now have enough adjustment to tune the audio to the levels where it is understandable and not so severely overdriven.
