I've got a confusing question to ask about scanning on the Kenwood NX series of radios, so please bear with me.
I understand they can use a scan list, or simply scan zones or channels based on what you have selected. I prefer to be able to control my zone and channel scanning from the radio, if I need to alter it. I have my 5200 programmed to be able to zone add, zone delete, and scan add and scan delete from the controls.
The problem is, every time I write to the radio, all those settings get jumbled, and I have to go back through every channel and zone and make sure everything is selected or deselected to my preferences. I cannot find in the software where this feature is controlled. "Scan Add" is an option for each channel, and for every Zone under Zone Edit, but it does not seem to control which channels are set to scan and which zones are set to scan when the radio is written to.
I hope that makes sense, and someone can clarify this for me. The manual doesn't seem very clear on this at all, even though its quite good in some other areas.
Thanks.
Thanks.
