jasej
Hi Group !
I have a situation with about 10 NX1300K radios, none of which have been able to communicate with an identical radio, which is in a working system.
I have the frequency information for this NX1300 working correctly.
I read it and from there and I write the information to the 10 radios, and none of them communicate with the working radio!
I know that the system works in NXDN and uses the 12.5 kHz direct channel and 6.25 kHz in the repeater channel system....
So I decided to test each of the 10 radios on direct frequency, in an analog system, which is the basic system, with the radio functioning correctly, using the 25 kHz and 12.5 kHz spacing.
I detected that none of the 10 radios work on 12.5 kHz spacing, only on 25 kHz modulation spacing.
So I see, they won't work on the NXDN repeater system which uses the Very Narrow and Narrow format...
The question is, is there some kind of TUNER for these Kenwood Radios, or is it just that those 10 devices are already damaged?
All radios have the latest firmware available installed!
Thanks.
Thanks.
