Kenwood NX3720 Issue
jasej
Hidalgo Texas
Hi my friends
I have a Kenwood NX3720 that won't turn on. I checked the DC line inside the radio and it seems fine. All six fuses in the radio are good.
If anyone in the group knows of any specific problems with this Kenwood model that prevent the radio from turning on, it would be very helpful in getting it fixed.
I know there may be more than one reason, but I hope it's just one specific reason!
Thank you my friends
regards.
What's the history of this radio? New, new to you, used, e-bay?
Have you tried applying +12v to the ignition sense line?
jasej
Hidalgo Texas
used, working every day, but suddenly stopped turning on !
And the ignition line? No, I haven't checked that.
It is used as a base radio, it uses an Astron SS18 power supply, it is working well
Pin 2 on the DB-15 is ignition switch.
If it wasn't set up for that before, and you didn't change it in programming, then you probably need to sit down with the service manual and go through it step by step. Or, send it off for repair. Sounds like you checked the obvious things.
jasej
Hidalgo Texas
Okay, thanks for your feedback. I'll keep looking for the manual. I'll print it out first since I have it in PDF.
Best regards.
